Does it damage the battery leaving the AC power cord plugged in? Or must I disconnect the power when the battery is fully charged?
ASUS X555L battery charging
Re: ASUS X555L battery charging
As long as the battery charger is working properly you should be able to keep the A.C. power cord plugged in.
When the battery is fully charged, the battery's charging circuit normally shuts off or it might provide a minimal trickle charge to the battery.
To be on the safe side, I would not leave the power cord connected if you are going to be away from your laptop for an extended period of time.
I would also leave the computer in an area where if something went radically wrong a laptop fire would not be able to easily spread to nearby flammable objects.
I don't have a laptop but they have been known to catch fire when the battery overheats or is poorly designed.
I frequently charge Ni-MH AA batteries and to be on the safe side, the battery charger is next to the bathroom sink and there are no towels nearby.
I have a high-end Ni-MH battery charger that keeps battery temperatures below ~ 30o(C), but I'm not taking any chances.
Performing a few web searches should lead to several reputable sites that can provide sound information.
Several searches to get you started:- is it ok to leave the a.c. power cord attached to a notebook when it is not in use?
- is it ok to leave the a.c. power cord attached to an asus notebook when it is not in use?
- should i leave my laptop plugged in all the time
- laptop battery fire hazard
Q9650 @ 4.10GHz [9x456MHz]
P35-DS4 [rev: 2.0] ~ Bios: F14
4x2GB OCZ Reaper PC2-8500 1094MHz @5-5-5-15
MSI N460GTX Hawk Talon Attack (1GB) video card <---- SLI ---->
Seasonic SS-660XP2 80 Plus Platinum psu (660w)
WD Caviar Black WD6401AALS 640GB (data)
Samsung 840 Pro 256GB SSD (boot)
SLI @ 16/4 works when running HyperSLICooler Master 120XL Seidon push/pull AIO cpu water cooling
Cooler Master HAF XB computer case (RC-902XB-KKN1)
Asus VH242H 24" monitor [1920x1080]
MSI N460GTX Hawk (1GB) video card
Logitech Z-5500 Digital 5.1 Speakers
win7 x64 sp1 Home Premium
HT|Omega Claro plus+ sound card
CyberPower CP1500PFCLCD UPSE6300 (R0) @ 3.504GHz [8x438MHz] ~~ P35-DS3L [rev: 1.0] ~ Bios: F9 ~~ 4x2GB Kingston HyperX T1 PC2-8500, 876MHz @4-4-4-10
Seasonic X650 80+ gold psu (650w) ~~ Xigmatek Balder HDT 1283 cpu cooler ~~ Cooler Master CM 690 case (RC-690-KKN1-GP)
Samsung 830 128GB SSD MZ-7PC128B/WW (boot) ~~ WD Caviar Black WD6401AALS 640GB (data) ~~ ZM-MFC2 fan controller
HT|Omega Striker 7.1 sound card ~~ Asus VH242H monitor [1920x1080] ~~ Logitech Z-5500 Digital 5.1 Speakers
win7 x64 sp1 Home Premium ~~ CyberPower CP1500PFCLCD U.P.S.
