I just put a newly built system into service that now after just a couple weeks is crashing a couple times a day with several different BSOD's and there are some other errors in the system log that concern me, the bugchecks are :
Other errors that concern me: "The driver detected a controller error on \Device\Hardisk1\DR1 (sometimes also appears as DR4)", "The IO operation at logical block address 1ab80 for Disk 1 was retired (lots of these saying different addresses 1ab00, 1ab180, 1ab100, 1ab080 etc)", "The driver \Driver\WudfRd failed to load for the device WpdBusEnumRoot\UMB\2&37c186b&0&STORAGE#VOLUME#_??_ USBSTOR#DISK&VEN_MAT****A&PROD_DMC-FH5&REV_0100#0000000000000000001X1201190465&0#"
The system specs are Asus M5A99FX PRO R2.0, AMD FX-4300 3.8Ghz CPU, 8GB Corsair Dominator CMP8GX3M2A1600C9, Thermaltake TR2-600 PSU, Windows 8 Pro, Asus Silent 210 video card, Western Digital 1TB Black Edition Hard Drive.
The first thing I tried was running the SeaTools diagnotics (the Western Digital Diags don't seem to work on UEFI bios yet) and the short and log tests came back clean so I don't think there's a problem with the hard drive but I can't figure out where these hard drive errors are coming from. Memtest86+ version 4.20 wouldn't run on this system, every time it booted from the CD I got the number "1004" scrolling down the screen and the test never ran. So I took the ram out and put it in a spare system with an Intel CPU and I'm in the process of running Memtest now, so far it's completed 1 pass without errors so I'm guessing that there's no outright memory problem.
Can anyone draw any conclusions from these bugchecks and error's? Could it be a bad motherboard or CPU? Any other troubleshooting steps that I could (other than what I've done) take to narrow down the problem?
Thanks,
- Norm
The bugcheck was 0x0000000a (0xfffffd7fffffffe0,0x0000000000000002, 0x0000000000000001, 0xfffff8024213c380). A dump was saved in C:\Windows\MEMORY.dmp (IRQ Not Less Or Equal)
The bugcheck was 0x000000d1 (0x0000000000000000,0x0000000000000002, 0x0000000000000008, 0x0000000000000000). A dump was saved in C:\Windows\MEMORY.dmp (Driver IRQL Not Less Or Equal)
The bugcheck was 0x0000004e (0x0000000000000002,0x000000000001dfcc, 0x000000000021efff, 0x0000000000000001). A dump was saved in C:\Windows\MEMORY.dmp (Invalid Data Access Trap)
The bugcheck was 0x00000139 (0x0000000000000003,0xfffff8800e472750, 0xfffff8800e4726a8, 0x0000000000000000). A dump was saved in C:\Windows\MEMORY.dmp (Kernel Security Check Failure)
Thanks,
- Norm
