NEW BUILD!! Sabertooth z77 will not turn on.
  • NEW BUILD!! Sabertooth z77 will not turn on.
    I was building my new system and when I was going to turn it on for the first time it does not do anything, i have tried using reset sw as pwr sw and using a screwdriver but nothing happens,
    the +sB led lights up green when i turn the psu on and the bios flashing button blinks blue light, 5 times slow and then 2 times fast.
    My system..
    Asus Sabertooth z77
    intel i5 3570k
    Corsair vengens 2x4GB memory
    Corsair H100i
    MSI GTX 660TI oc
    Coolermaster M2 720w silent pro PSU
    HAF X Nvidia edition Case
    Samsung 840 120GB SSD
    Re: NEW BUILD!! Sabertooth z77 will not turn on.
    Is the power supply's 8-pin EPS12V cable connected to the motherboard?
    Does your motherboard user manual provide any information about error codes for the flashing bios button?
    Q9650 @ 4.10GHz [9x456MHz]
    P35-DS4 [rev: 2.0] ~ Bios: F14
    4x2GB OCZ Reaper PC2-8500 1094MHz @5-5-5-15
    MSI N460GTX Hawk Talon Attack (1GB) video card <---- SLI ---->
    Seasonic SS-660XP2 80 Plus Platinum psu (660w)
    WD Caviar Black WD6401AALS 640GB (data)
    Samsung 840 Pro 256GB SSD (boot)
    SLI @ 16/4 works when running HyperSLI
    Cooler Master 120XL Seidon push/pull AIO cpu water cooling
    Cooler Master HAF XB computer case (RC-902XB-KKN1)
    Asus VH242H 24" monitor [1920x1080]
    MSI N460GTX Hawk (1GB) video card
    Logitech Z-5500 Digital 5.1 Speakers
    win7 x64 sp1 Home Premium
    HT|Omega Claro plus+ sound card
    CyberPower CP1500PFCLCD UPS
    E6300 (R0) @ 3.504GHz [8x438MHz] ~~ P35-DS3L [rev: 1.0] ~ Bios: F9 ~~ 4x2GB Kingston HyperX T1 PC2-8500, 876MHz @4-4-4-10
    Seasonic X650 80+ gold psu (650w) ~~ Xigmatek Balder HDT 1283 cpu cooler ~~ Cooler Master CM 690 case (RC-690-KKN1-GP)
    Samsung 830 128GB SSD MZ-7PC128B/WW (boot) ~~ WD Caviar Black WD6401AALS 640GB (data) ~~ ZM-MFC2 fan controller
    HT|Omega Striker 7.1 sound card ~~ Asus VH242H monitor [1920x1080] ~~ Logitech Z-5500 Digital 5.1 Speakers
    win7 x64 sp1 Home Premium ~~ CyberPower CP1500PFCLCD U.P.S
      try with a minimal hardware setup,for example
      one ram stick installed no ssd or graphic card connected and use the onboard display ports,see if it boots up then
      Gigabyte z77x UP4-TH F11c Modded Bios
      Intel i7 3770k 24/[email protected] 1.38v Turbo llc +0.165v dvid multithreading enabled
      Samsung Green(MV-3V4G3D/US) 8GB @2133mhz 9-10-10-21-1t 1.55v
      Thermalright Silver Arrow Cpu Cooler
      1xSamsung 840 pro 256 Gb SSD windows 8.1 pro 64bit
      1xSamsung f4 HD204UI 2tb hard drive Storage
      Powercolor 7970 3gb V3 @1150mhz core/1700mhz mem,1.150v Accelero aftermarket air cooler 55c max
      Razer Lycosa Keyboard
      Logitech X-530 5.1 Speakers
      Lite-On iHAS124-19 24x Sata DVDRW
      K-World Hybrid DVB-T 210SE Digital T.V Card
      L.G E2260V L.E.D 1920x1080 Monitor
      Xfx Pro 750w silver rated Psu 80+
      Fractal Arc Midi Case
      http://i38.tinypic.com/14myvfa.jpg x58 ud5 <=3.8ghz + 4.2ghz Overclock Template!!
      http://www.youtube.com/user/warren304#p/u Visit Me On Youtube
      Lots Of Gaming Videos With X58 Ud5 System And Gpu On My Youtube Channel!!
      Just Uploaded New Battlefield 4 Video!!!!!!!!!!!!!!!!!!!!!!
        The 8 pin connector was connected and the manual did not provide any error codes,
        I Jump started the PSU to eliminate that, than i took the motherboard out of the case an set it up on a cardboard box
        started it there with nothing on it not even a memory stick only CPU cooler an power supply.
        and it started like that but the memory LED went evil red.
        then i started putting things on the board one by one ended up with everything connected except for the case fans.
        then i saw that the bios flash button was normal and remembered that there were 2 metal things on beside him earlier and
        then i realized what had been the problem.
        The I/O shield was holding the button on so the motherboard would not start with it in the case.
        so if someone has this problem in the future, Remember There is not supposed do be light on the bios button unless it is active
          Thanks for the update, glad to hear that you solved the problem.
