Raid questions for Maximus V Formula mb
  • Raid questions for Maximus V Formula mb
    Please excuse my noobness I've never used raid before and I may be way off with my understanding of the mb to start with. As I understand it this board has 8 serial ata ports. 4 on the intel controller, [email protected] and [email protected] 4 on the asmedia controller that are all sata3. Can you have 2 separate raid config on this board?
    2x128gb ssd in one raid, running os and some games on the intel pch ?
    Another ssd as cache for a 1tb hdd on the AS media controller?
    Is this a possible scenario?
    Re: Raid questions for Maximus V Formula mb
    no you can only have one controller running raid,you should have 2 intel sata3 2 asmedia and four intel sata2???
    you can have a raid array on the intel sata2 and have your operating system on an ssd on the intel sata3 and have another 60gb ssd on intel sata3 caching the raid array,aslong as the os ssd isnt part of the array it will work fine
    Gigabyte z77x UP4-TH F11c Modded Bios
    Intel i7 3770k 24/[email protected] 1.38v Turbo llc +0.165v dvid multithreading enabled
    Samsung Green(MV-3V4G3D/US) 8GB @2133mhz 9-10-10-21-1t 1.55v
    Thermalright Silver Arrow Cpu Cooler
    1xSamsung 840 pro 256 Gb SSD windows 8.1 pro 64bit
    1xSamsung f4 HD204UI 2tb hard drive Storage
    Powercolor 7970 3gb V3 @1150mhz core/1700mhz mem,1.150v Accelero aftermarket air cooler 55c max
    Razer Lycosa Keyboard
    Logitech X-530 5.1 Speakers
    Lite-On iHAS124-19 24x Sata DVDRW
    K-World Hybrid DVB-T 210SE Digital T.V Card
    L.G E2260V L.E.D 1920x1080 Monitor
    Xfx Pro 750w silver rated Psu 80+
    Fractal Arc Midi Case
    http://i38.tinypic.com/14myvfa.jpg x58 ud5 <=3.8ghz + 4.2ghz Overclock Template!!
    http://www.youtube.com/user/warren304#p/u Visit Me On Youtube
    Lots Of Gaming Videos With X58 Ud5 System And Gpu On My Youtube Channel!!
    Just Uploaded New Battlefield 4 Video!!!!!!!!!!!!!!!!!!!!!!
      Thanks for the quick reply. LOL yeah i thought i may be grasping at straws with 2 raids
      I thought the ssd caching was capped at 60gb as well but this guy say "even 120gb" at around the 22.20-22.40 mark ROG Maximus V Formula Motherboard+ThunderFX audio bundle Hands-On Overview - YouTube Does he mean you can use a 120gb for caching but olny get to use half of it?
        yeah,max space for caching is 60gb,a cheap 60gb drive would work fine,then you can cache your raid array to speed things further
          Dam. I thought I was getting to understand this but now I'm confused again.. Isn't caching a 60gbssd with a hdd raid? or is that what you mean buy "then you can cache your raid array to speed things further"
          If you use a larger drive than 60gb, what happens with the rest of the drive?
          • #6
            i dont know,i think you can use it if you just make a 60gb partition
            i mean if your hdd's are in raid0 you can add in a 60gb ssd and cache the raid 0 drives,then you'll get raid 0 speed of the hdd's and ssd speed of the 60gb caching drive
            all caching is is the most regularly used data gets written to the caching drive and used from that,this is what gives you ssd speeds without the space limits
            • #7
              I think I get the picture now.
              thanks
