I received this error message today after waking my computer up from stand-by mode.
Only action taken was to backup my files, please help ASAP!
Log Name: System
Source: Microsoft-Windows-DiskDiagnostic
Date: 9/28/2012 2:08:08 AM
Event ID: 1
Task Category: None
Level: Critical
Keywords:
User: SYSTEM
Computer: James-PC
Description:
Windows Disk Diagnostic detected a S.M.A.R.T. fault on disk Hitachi HTS547575A9E384 ATA Device (volumes C:\). This disk might fail; back up your computer now. All data on the hard disk, including files, documents, pictures, programs, and settings might be lost if your hard disk fails. To determine if the hard disk needs to be repaired or replaced, contact the manufacturer of your computer. If you can't back up (for example, you have no CDs or other backup media), you should shut down your computer and restart when you have backup media available. In the meantime, do not save any critical files to this disk.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-DiskDiagnostic" Guid="{E670A5A2-CE74-4AB4-9347-61B815319F4C}" />
<EventID>1</EventID>
<Version>0</Version>
<Level>1</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000000</Keywords>
<TimeCreated SystemTime="2012-09-28T09:08:08.370908100Z" />
<EventRecordID>31528</EventRecordID>
<Correlation ActivityID="{FB8DA808-D6A6-4E88-AD6D-FF63F877FD41}" />
<Execution ProcessID="520" ThreadID="198348" />
<Channel>System</Channel>
<Computer>James-PC</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="DiskFriendlyName">Hitachi HTS547575A9E384 ATA Device</Data>
<Data Name="VolumeNames">C:\</Data>
<Data Name="HardwareID">IDE\DiskHitachi_HTS547575A9E384_ ________________JE4OA50A</Data>
</EventData>
</Event>
Asus Computer Specs:
Manufacturer: Asustek
Processor: Intel Core i5 CPU M 430 @ 2.27 GHz 2.27 GHz
RAM: 4 GB
System Type: Windows 7 Home Premium 64-bit
Log Name: System
Event ID: 1
Task Category: None
Level: Critical
Keywords:
User: SYSTEM
Computer: James-PC
Description:
Event Xml:
<System>
<Level>1</Level>
<Task>0</Task>
<Opcode>0</Opcode>
</System>
<EventData>
</EventData>
</Event>
RAM: 4 GB
