P8Z68-V Pro/2600K - Help getting past 4.5GHz
  • P8Z68-V Pro/2600K - Help getting past 4.5GHz
    Attached is the path I have been on to OC the system using Offset Mode. What suggestions do you guys have for getting past the BSOD wall I get to at 4.6GHz. Do I need to increase the memory controller voltage to handle the 8GB of 1600-C8 memory? 0X124 seems to have a lot of variables! OR are one of the other settings that were recommended for fixed voltage causing a problem. I have tried lower settings for LLC instead of "Medium" but don't seem to get enough Vcore? Help appreciated.
    Re: P8Z68-V Pro/2600K - Help getting past 4.5GHz
    Thanks all for the help and suggestions! I finally dropped back and got this thing to run at 4.5GHz in Offset Mode with LLC=Auto and Offset= + Auto. Way too easy! I also got it to run "stable" (Prime 95 v27.7 for 3+ hours) setting the LLC=High and Offset to + 0.005. But... at 4.6GHz the max core temps running Prime95 were too high for me at 65-71-71-68C. So for 24-7 it's 4.5GHz on Auto/Auto.
      anything under 80c is fine for sb,you probably need more cpu voltage/offset and a higher llc level for 4.5ghz+
      Gigabyte z77x UP4-TH F11c Modded Bios
      Intel i7 3770k 24/[email protected] 1.38v Turbo llc +0.165v dvid multithreading enabled
      Samsung Green(MV-3V4G3D/US) 8GB @2133mhz 9-10-10-21-1t 1.55v
      Thermalright Silver Arrow Cpu Cooler
      1xSamsung 840 pro 256 Gb SSD windows 8.1 pro 64bit
      1xSamsung f4 HD204UI 2tb hard drive Storage
      Powercolor 7970 3gb V3 @1150mhz core/1700mhz mem,1.150v Accelero aftermarket air cooler 55c max
      Razer Lycosa Keyboard
      Logitech X-530 5.1 Speakers
      Lite-On iHAS124-19 24x Sata DVDRW
      K-World Hybrid DVB-T 210SE Digital T.V Card
      L.G E2260V L.E.D 1920x1080 Monitor
      Xfx Pro 750w silver rated Psu 80+
      Fractal Arc Midi Case
      http://i38.tinypic.com/14myvfa.jpg x58 ud5 <=3.8ghz + 4.2ghz Overclock Template!!
      http://www.youtube.com/user/warren304#p/u Visit Me On Youtube
      Lots Of Gaming Videos With X58 Ud5 System And Gpu On My Youtube Channel!!
      Just Uploaded New Battlefield 4 Video!!!!!!!!!!!!!!!!!!!!!!
