Since updating from the 1.0.1.7f firmware to 1.0.1.8b firmware, my RT-N56U router intermittently has DNS resolution problems. Has anyone else been experiencing this issue?
RT-N56U 1.0.1.8b firmware issue
Re: RT-N56U 1.0.1.8b firmware issue
I downgraded the firmware back to 1.0.1.7f, and the intermittent DNS resolution issues went away; although, this could still be a coincidence, I highly doubt it.
I did run into a problem flashing the firmware initially; the router went into recovery mode after the flashing, possibly because I was uploading the firmware binary file from the actual USB drive that was connected to the router -- I'm not sure. At that point, it became necessary to connect a notebook computer to the router via a USB cable and install the firmware recovery utility from the RT-N56U CD, so I could flash the 1.0.1.7f firmware. Luckily, I had another copy of the firmware available on a thumb drive; the firmware recovery utility does not come with any version of the RT-N56U firmware, so it is always important to have a copy of the binary firmware file easily accessible.
hard design flaw imo. A good product uploads/reads the entire FW before it starts to flash, aka using the internal usb port shouldn't be a problem. Had similar problems with my dlink router at the beginning, but on the newest FW it runs like a pro.
Good you got it fixed though, and even better you share it here for others to read and learn from.My advice - never visit a short-url, no matter who gives it to you. You can't trust any source at any time when you don't know your target
Whitey:Snuggles: Zotac Zbox HD-ID40 (Atom d525, worst purchase ever on cpu), Patriot Pyro 60GB (Thanks to Tweaktown Giveaway), 4GB 800' DDR2 SO-DIMM
Bcube (NAS): ASUS F1A75-I Deluxe, AMD A6-3500 @ 2.1GHz, LSI 9240-8i (M1015) controller, GSkill Ares 1866 8GB blue kit, 4x Seagate SV35.5 2TB, 1x Seagate Barracuda 1.5TB, 1x Samsung HD103UJ, 1x Samsung F4 2TB, Temp. Rebel9 Alu case, Corsair H60, 2x Icy Dock MB973SP-B, NZXT UI01, Enermax T.B. Silence on docks and cpu, Aurum 500W gold PSU. (Draws 65W average, doesn't peak above 100W at any time)
