Will HD 6950 2GB Fit My Case?
  • Will HD 6950 2GB Fit My Case?
    Hi:
    Recently performed major upgrades to system. Not happy with my current graphics card, EVGA GTS 450 1GB. I looked at several cards, and decided to switch to AMD and settled on Asus HD 6950 2GB.
    I have an Asus P8P67 LE Rev 3.0 MB installed in a Thermaltake V3 Black chassis. The 6950 card dimensions are given as 11.7" x 5". The case measures about 12.25" from the inside back to the HDD bays. Will this card fit?
    Thanks,
    Dave
    Asus P8P67 LE Rev. B3
    i5-2500 CPU (6M Cache, 3.30 GHz)
    8GB RAM
    Asus HD 6950 DirectCU II 2GB GDDR5 GPU
    WD 500GB 7200 HDD
    LG W2442 PA 24" Monitor
    Samsung Syncmaster 216BW 22" Monitor
    Thermaltake V3 Black Mid Tower
    Thermaltake TR2 RX 750W PSU
    Logitech Z623 2.1 Speakers.
    Logitech G5 Gaming Mouse
    Acer Generic Keyboard
    Re: Will HD 6950 2GB Fit My Case?
    have you measured inside with a tape measure just to makesure?from the measurements youve quoted then it should fit
    Gigabyte z77x UP4-TH F11c Modded Bios
    Intel i7 3770k 24/[email protected] 1.38v Turbo llc +0.165v dvid multithreading enabled
    Samsung Green(MV-3V4G3D/US) 8GB @2133mhz 9-10-10-21-1t 1.55v
    Thermalright Silver Arrow Cpu Cooler
    1xSamsung 840 pro 256 Gb SSD windows 8.1 pro 64bit
    1xSamsung f4 HD204UI 2tb hard drive Storage
    Powercolor 7970 3gb V3 @1150mhz core/1700mhz mem,1.150v Accelero aftermarket air cooler 55c max
    Razer Lycosa Keyboard
    Logitech X-530 5.1 Speakers
    Lite-On iHAS124-19 24x Sata DVDRW
    K-World Hybrid DVB-T 210SE Digital T.V Card
    L.G E2260V L.E.D 1920x1080 Monitor
    Xfx Pro 750w silver rated Psu 80+
    Fractal Arc Midi Case
    http://i38.tinypic.com/14myvfa.jpg x58 ud5 <=3.8ghz + 4.2ghz Overclock Template!!
    http://www.youtube.com/user/warren304#p/u Visit Me On Youtube
    Lots Of Gaming Videos With X58 Ud5 System And Gpu On My Youtube Channel!!
    Just Uploaded New Battlefield 4 Video!!!!!!!!!!!!!!!!!!!!!!
      Thanks. Yes, I measured with a steel ruler. I know the power connectors go on the top (side?) and not the back. I am just not sure what the 11.7" refers to. On my current card, the spec dimensions seem to refer to the PCB card itself, excluding the cooler and pin-connectors. If someone has an Asus HD 6950 2G in their PC, they might be able to give me exact outside dimensions.
      8GB RAM
      WD 500GB 7200 HDD
        11.7" will refer to the card itself,with 12.25" you should have a bit of space for the power connectors to fit,or if they fit on the top then even better,i have a 5870 card which measures 10 and a half inches and power connects at the back,it fits fine in my casecom casewith a few centimetres to spare,sorry i dont have the same card/case but i think youll be fine,maybe someone who has same card can comment further
          Found evidence the 6950 will fit (lengthwise at least). Did a search on Youtube and found this Review and Benchmark video where he physically measured the card. It's 11.5". Thank you for all your input. Now I just have to get up the nerve to pony up the dough.
          Cheers,
          Dave
          8GB RAM
          WD 500GB 7200 HDD
          • #6
            Case manufacturer says no. He said that model case will accept up to a maximum 10.5" long graphics card. Oops. Now what? Can't afford too many more upgrades.
            What about modifying the case to fit? It actually looks like it will fit, unless there are space requirements for heat dissipation.
            Any suggestions?
            Thanks,
            Dave
            8GB RAM
            WD 500GB 7200 HDD
            • #7
              What's the case looklike regarding the hdd cage? My 5870 clears the cage giving me a clear run from the back to the front of the case inside,if yours is the same it should fit,thought you said you had over 12inches spare? If so again it should fit
              • #8
                Thanks. I think it might work. The card encroaches slightly above bottom bay, but shouldn't touch it. I'm guessing the case manufacturer is allowing for pin connectors and cables at the back of the card. In the case of the 6950, this is not an issue.
                8GB RAM
                WD 500GB 7200 HDD
                • #9
                  If you do get the card,post back on how you get on,it should fit imo but if not you can modify the case fairly easy,at the most you would lose a hdd space if you hacksawed a piece out,but i dont think it would come to that
                  • #10
                    Card fit no problem. No case mod required. Thanks for the feedback. No thanks to case manufacturer tech support who said it wouldn't fit.
                    8GB RAM
                    WD 500GB 7200 HDD
                    • #11
                      i was sure it would fit,cant go wrong when you measure yourself,did it clear or fall short of the hdd bay?
                      • #12
                        Thanks. I had about 3/4" clear. I can't install any drives in 2 bays, but at least it works. If I go nuts and decide to set up Crossfire with 2 cards, I'll have to get a bigger case. The second card might fit, but would be touching the PSU. :)
                        8GB RAM
                        WD 500GB 7200 HDD
                        • #13
                          Just a couple of photos of card installed.
                          Click image for larger version
                          8GB RAM
                          WD 500GB 7200 HDD
                          • #14
                            thats a huge card,my case is very similar to yours apart from my hdd's face forwards towards the side panel,having the two power connectors on the side and not the back of the card helped you alot
                            • #15
                              You're right. If pin connectors were at the back, I'd be in trouble.
                              Love this GPU!! Been playing Deus Ex HR at max settings with no instability. My only complaint is it heats up when I'm running 2 monitors in Extended Display mode. I guess that's to be expected. It goes from about 33C to 43C at idle.
                              Don't think I'll play too much with over-clocking this card, just yet, but will investigate cooling options. Fan tweaking?
                              8GB RAM
                              WD 500GB 7200 HDD
