I'm trying to figure out how to OC my i5 2500K in the BIOS for my P8Z68-V Pro. I've checked the CPU configuration and it looks like I can't do so because the BIOS says that the CPU ratio range is 16-33.
P8Z68-V Pro - how to OC an i5 2500K in BIOS?
ASUS P8Z68-V Pro (BIOS version 3402) | Core i5 2500K (4GHz) | 8GB Corsair Vengeance CMZ8GX3M2A1600C8R DDR3-1600 CL8 (2x4GB) | Palit GTX 680 Jetstream 2GB | ASUS Xonar D2X | WD Caviar Black 1TB (WD1002FAEX) | LG CH10LS20 Blu-ray/DVD-RW combo drive | Corsair HX650 | Antec Nine Hundred Two V3 | Samsung 2333SW (23" LCD @ 1920x1080) | Windows 7 Ultimate SP1 x64 -
Re: P8Z68-V Pro - how to OC an i5 2500K in BIOS?
It should go higher than 33x,try loading optimized defaults, for 4.2ghz it would be 42x100,that mb and CPU go higher than 5ghz,using latest BIOS?Gigabyte z77x UP4-TH F11c Modded Bios
Intel i7 3770k 24/[email protected] 1.38v Turbo llc +0.165v dvid multithreading enabled
Samsung Green(MV-3V4G3D/US) 8GB @2133mhz 9-10-10-21-1t 1.55v
Thermalright Silver Arrow Cpu Cooler
1xSamsung 840 pro 256 Gb SSD windows 8.1 pro 64bit
1xSamsung f4 HD204UI 2tb hard drive Storage
Powercolor 7970 3gb V3 @1150mhz core/1700mhz mem,1.150v Accelero aftermarket air cooler 55c max
Razer Lycosa Keyboard
Logitech X-530 5.1 Speakers
Lite-On iHAS124-19 24x Sata DVDRW
K-World Hybrid DVB-T 210SE Digital T.V Card
L.G E2260V L.E.D 1920x1080 Monitor
Xfx Pro 750w silver rated Psu 80+
Fractal Arc Midi Case
http://i38.tinypic.com/14myvfa.jpg x58 ud5 <=3.8ghz + 4.2ghz Overclock Template!!
http://www.youtube.com/user/warren304#p/u Visit Me On Youtube
Lots Of Gaming Videos With X58 Ud5 System And Gpu On My Youtube Channel!!
Just Uploaded New Battlefield 4 Video!!!!!!!!!!!!!!!!!!!!!!
I'm using latest BIOS (0651). I'd put up a printscreen of what I see but the F12 PrintScreen function doesn't detect my flash drive even though it's plugged in (doesn't appear on the list of flash drives to select from).ASUS P8Z68-V Pro (BIOS version 3402) | Core i5 2500K (4GHz) | 8GB Corsair Vengeance CMZ8GX3M2A1600C8R DDR3-1600 CL8 (2x4GB) | Palit GTX 680 Jetstream 2GB | ASUS Xonar D2X | WD Caviar Black 1TB (WD1002FAEX) | LG CH10LS20 Blu-ray/DVD-RW combo drive | Corsair HX650 | Antec Nine Hundred Two V3 | Samsung 2333SW (23" LCD @ 1920x1080) | Windows 7 Ultimate SP1 x64
Have you typed in 45x? Or used the + key to increase CPU multi? Does the oc software oc higher than 33x for you?
Here's a site you can check out,some BIOS settings/screenshots at the bottom of the page
Last edited by wazza300; 07-19-2011, 07:17 AM.Gigabyte z77x UP4-TH F11c Modded Bios
